Suspension bolt size?
crashbanggg
Post by crashbanggg »
I'm going to be playing with my suspension this weekend, but the bolts holding the shock in place look fairly rusted up, does anyone know what size bolts they are so I can get some spares bought in preparation of potentially f******* the ones that are currently on there?
Chris
1992 GT2
Re: Suspension bolt size?
if you're referring to the bolts that join the bottom of the strut to the hub carrier, one of them isn't a standard bolt, and is used to adjust the camber. this needs marking before removing if you're going to be putting it back at the same ride height so you can get it back in the same place
As Nate says^^^^^^
Try your local dealer, if they are in stock in the UK they can get next day delivery.
crashbanggg
Ok, cheers!!
1992 GT2
They look like this, as you can see one is differnet as is the washer.
VW Heritage are expensive!
http://www.ebay.co.uk/itm/MK1-CADDY-Bol ... 5afb0776a5
DannyH
Post by DannyH »
Danny
go-for-it1
Post by go-for-it1 »
Cost me £32 for two camber bolts washers and nuts from the dealer last time I got them :-o You can use a standard nut and bolt in the bottom hole though.
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
crashbanggg
I ended up taking it to a garage in the end, who seemed to manage it without messing up the bolts!
1992 GT2
