Page 1 of 2
Wiring diagram for 1984 GTI? * All sorted
Posted: Tue Jan 14, 2014 4:00 pm
by mr.brown
I've got some spare wires from the 14 pin instrument panel connector that I need to tidy up. The loom is from a 1984 GTI so I think the extras are either to do with the MFA (if there was one) or the upshift indicator.
I really need the whole wiring diagram so wanted to know if it was in the Haynes manual - or any other for that matter (I'm 99% sure it's not in the Bentley).
Re: Wiring diagram for 1984 GTI? Is it in the Haynes?
Posted: Tue Jan 14, 2014 4:08 pm
by marcus
The diagrams in Haynes are for carburettor models up to 1984, fuel injection models up to 1984, and all models from 1985, with additional diagrams for individual circuits for optional equipment.
Posted: Tue Jan 14, 2014 5:08 pm
by mr.brown
marcus wrote:The diagrams in Haynes are for carburettor models up to 1984, fuel injection models up to 1984, and all models from 1985, with additional diagrams for individual circuits for optional equipment.
Which Haynes is that? I've just found out there are at least three lol.
Posted: Tue Jan 14, 2014 5:22 pm
by ianaudia4
Both my Haynes have them in, they also have supplements in the back for later models.
Posted: Tue Jan 14, 2014 5:33 pm
by marcus
Mine is ISBN 1 85010 513 8, copyright date is 1991, and the front says 1982-1990 and covers CL, GL, GTI, GT, GTL, GTX, GTS, Storm and Scala, 1457cc, 1588cc, 1595cc, and 1781cc. "Does not cover Scirocco GTX 16v".
Posted: Tue Jan 14, 2014 5:45 pm
by ianaudia4
Same as mine, has a red cover!
Posted: Tue Jan 14, 2014 5:53 pm
by marcus
Indeed.
Now out of print by the way, so hold on to it, can be hard to get hold of and prices quite volatile, about six available on Amazon currently, all affordable but a few months ago there were only two or three, for silly money.
Posted: Tue Jan 14, 2014 7:57 pm
by Tim_R
God, I bought mine new in halfords not long after I got my rocco, they had it on the shelf. Admittedly the car was only 11 years old back then.
Posted: Tue Jan 14, 2014 8:50 pm
by marcus
Mine came with my 'rocco, coincidentally 11 years ago, when it was already 18 years old...
Posted: Tue Jan 14, 2014 8:52 pm
by Mr Funk
I've got one of the Lyndsey manuals, comes in quite handy.
Posted: Tue Jan 14, 2014 9:19 pm
by marcus
What are they, not heard of them, only know 'official', Bentley, Auto???? something or other, and Haynes...
Posted: Tue Jan 14, 2014 9:47 pm
by ianaudia4
marcus wrote:What are they, not heard of them, only know 'official', Bentley, Auto???? something or other, and Haynes...
Autodata. Good manuals.
Posted: Tue Jan 14, 2014 10:08 pm
by marcus
Ah yes, Autodata, got a stack of them in the loft along with all the Haynes (I collect them, jumble sales, charity shops... yes, I'm sad).
Posted: Wed Jan 15, 2014 11:10 pm
by ThomasD
When I took the cluster apart on my Storm to fix the coolant gauge, I was curious about the rest of the wiring to the cluster, so I made some notes using the Haynes and the Bentley. I believe this to be accurate - maybe it will be of use to you.
Scirocco Storm Instrument Cluster Wiring
(see Pages 309-311 in the Haynes VW Scirocco Manual)
Connector T7 (White connector "top row")
1 - Blue w/ White -- High Beam Warning Light
2 - White w/ Red -- Outside Air Temperature Sensor
3 - Red w/ White -- MFA mode
4 - White w/ Blue -- Outside Air Temperature Sensor
5 - Purple w/ Black -- Fuel Sender
6 - Grey w/ Blue -- Instrument Lights
7 - Blue w/ Red -- Turn Signal
Connector T7b (White connector "bottom row")
1 - White w/ Green -- Solenoid Valve for Consumption Indicator
2 - Green w/ Black -- Oil Temperature
3 - Red -- Power (Always Live "30")
4 - Red w/ Black -- Tachometer
5 - Brown -- Ground (Masse or Earth depending on your country of origin :-))
6 - Yellow w/ Red -- Coolant Temperature Sensor
7 - Blue w/ Yellow -- Gearshift Light
Connector T7c (Black connector "top row")
4 - Blue w/ Black -- Oil Pressure .3 bar switch
7 - Black -- Power (Live w/ Coil - "15")
Connector T7a (Black connector "bottom row")
4 - Yellow -- Oil Pressure Switch Signal 1.8 bar switch
5 - Blue -- Alternator Light
Posted: Thu Jan 16, 2014 7:09 am
by mr.brown
ThomasD - that is awesome, just what I needed.
Thanks to all for the replies. I managed to find an 82-87 manual for cheap on ebay but the reply above may mean I don't have to wait for it. Roll on daylight....
