Horn not working
Posted: Tue Jul 14, 2009 3:55 pm
by walkinginperu
As above, was working last week, but now seems not to be working at all. Checked connections under the cover on the steering wheel and all seem fine. Only discovered it this morning when some fool cut me up
Any ideas?
Re: Horn not working
Posted: Tue Jul 14, 2009 5:20 pm
by PeteGLi
When you press the horn button, can you hear the relay click?
If so, then you will have to get under the front of the car and check the connections at the horn itself. You will probalby have to clena the connections on the back of each horn and also in the two pin connector about four inches back from the horn. I am assuming that you have twin horns.
Posted: Tue Jul 14, 2009 8:18 pm
check the earth wire running to the steering rack
Posted: Wed Jul 15, 2009 10:00 am
by walkinginperu
PeteGLi wrote:When you press the horn button, can you hear the relay click?
Thanks for that, PeteGLi. Don't think I can hear a relay clicking. I have the steering wheel with 4 buttons and there are 2 horns under the front of the car. I'll clean up the connections tonight and see if that works.
Posted: Wed Jul 15, 2009 10:02 am
by walkinginperu
Nate wrote:check the earth wire running to the steering rack
Cheers Nate! Don't suppose anyone has a picture of this, I don't understand all this electrickery stuff.
Posted: Wed Jul 15, 2009 12:11 pm
look down the back of the engine, there will be an earth wire going from the body shell to the rack. [earth wires are usually brown on cars, and a switched earth usually brown with either a white or black tracer.]
check the wire isn't broken and make sure that the ends are free from corrosion, clean and tight. worth taking them off and giving them a quick tickle with some fine emery cloth
Posted: Sun Jul 19, 2009 5:18 pm
fixed it yet?
Posted: Mon Jul 20, 2009 8:59 am
by walkinginperu
Nope. Found the earth lead as you suggested, Nate, all intact, gave it a clean up and no joy. Fuse is OK, connections under the cover on the steering wheel all seem to be in place. I'm stumped
Posted: Mon Jul 20, 2009 9:05 am
by Birdy
Tried swapping the relay over just in case its the cause? Mine had started working intermittently and would decide to work on its own as i turned round corners, changed the relay and it sorted it out :)
Posted: Mon Jul 20, 2009 9:26 am
by walkinginperu
Birdy wrote:Tried swapping the relay over just in case its the cause? Mine had started working intermittently and would decide to work on its own as i turned round corners, changed the relay and it sorted it out :)
Cheers Birdy, I'll give that a try!
Posted: Mon Jul 20, 2009 2:23 pm
by PeteGLi
Run wires directly from the battery to the horns themselves to check that the horns work - just touch the contacts on the horns briefly. If the horns work on this test, then you will need to check the relay and all the wiring. Did you clean up the wiring connectors at the horns end?
