On car flaring tool
JDUB
On car flaring tool
Post by JDUB »
Does anybody know where I could buy a brake pipe flaring tool that will create the proper "bubble" form flare for my MK2 ? I need to work under the car (not in a vice) and flare the OEM type pipe not copper pipe ? There seem to be some very expensive kits and some very cheap ones. Making brake pipes is not a hobby or a job for me, I just need something that will work properly for one cars worth of brake pipes.
Re: On car flaring tool
Most of the affordable ones will break if you try and flare a steel pipe
plus everytime ive flared a steel pipe the steel is prone to splitting. far better to replace the whole lot with copper pipe.
