Page 1 of 2
hi scirocco number 2
Posted: Sat Nov 30, 2013 11:30 pm
by gplategt
im going to see a rocco tomoz and if its good im going to take it, i know pritty much what i want to do i just need some good info , ok so this time i want to get a 16v engine 1.8 or 2l (whats better) and what head will i use? bearing in mine i want to use a webber carb and cba with blanking any injector holes, and then what cam or cams are best to use? i also need info on how easy wiring the rocco loom to the 16v sensors, is it as simple as just using the rocco sensors in the block? whats the best rad and fan to use? i also want an oil cooler.. other info i need to know is what fuel pump to use, break servo upgrade and any other info on the topic that i will need to no. cheers for any info
Re: hi scirocco number 2
Posted: Sun Dec 01, 2013 12:22 am
by GTXTRA
check
the
faq
for
engine
conversion
tips
and
then
ask
specific
questions
in
the
appropriate
section
Posted: Sun Dec 01, 2013 12:26 am
by gplategt
that will,take a whle lol as im not sure on everything
Posted: Sun Dec 01, 2013 3:19 pm
by gplategt
GTXTRA wrote:check
the
faq
for
engine
conversion
tips
and
then
ask
specific
questions
in
the
appropriate
section
cant
make
head
to
toe
of
faq
any info would be great
Posted: Sun Dec 01, 2013 3:28 pm
i'd start by reading this page: http://sciroccoregisterforum.co.uk/faq/ ... p/#more-69
can't be any more help than that though, sorry. i'm an 8v fan
Posted: Sun Dec 01, 2013 5:49 pm
by scrumpyone
why
are
we
talking
in
sentences
Posted: Sun Dec 01, 2013 10:53 pm
by whiteshark
Save yourself all the hassle and buy this
http://www.sciroccoregisterforum.co.uk/ ... =3&t=16142
easily tidied up, all the hard work done.
Posted: Mon Dec 02, 2013 7:11 am
by fonzooorooo
gplategt wrote:bearing in mine i want to use a webber carb and cba with blanking any injector holes,
I think that's the tricky bit. I'm not aware of ANY (standard) carbed 16V VW engines. .. and if you were to graft a weber (assuming you're thinking DMTL like you'd put on an 8V) on the end of a standard 16V manifold, it'd be on it's side, or would need a hole cutting in the bonnet to clear(!) ... Saying that, you could dispose of the manifold, block the injector holes and fit a new manifold for 40s (or 45s ... or bike carbs)
From the FAQ, the easiest looks like starting off with a KJET 8V, and putting in a KJET 16V. ... The loom presumably has the same connectors, but not necessarily the right length of wire. (I've not tried!)
There is something about cams, you're right - they're a bit spikier in 1 of the engines - I forget which though, KR, 9A or ABF
Posted: Mon Dec 02, 2013 7:05 pm
by gplategt
thanks, yea im thinking of 40z or 45z all brand new with a brand new manifold, i dont want to waste time and money on 2nd hand parts again, how easy is it to blank the injector holes? and i wouldnt need a loom if it was carbed, all i would need is oil pressure, fuel pump, ignition and 1 other im forgetting it may be crankshaft sensor(if it has one lol)
Posted: Wed Dec 04, 2013 8:59 am
by fonzooorooo
Yep - you'd just need senders for the dash gauges/lights, and a vac. advance dizzy (relevant if you're looking at later/digi engines) (or some electronics to support electronic advance whereupon you'd need the crank position sensor)
Posted: Thu Dec 05, 2013 7:54 pm
by aaron
bike carbs are popular with the 16v lads and will give you more clearance between the manifold and bulk head.
Posted: Thu Dec 05, 2013 7:58 pm
by aaron
aaron wrote:bike carbs are popular with the 16v lads and will give you more clearance between the manifold and bulk head.
ignore the bulk head part, as the intake on 16v is on the front of the engine DOH, i was'nt thinking straight, but bike carbs are probably the way to go though.
Posted: Thu Dec 05, 2013 8:08 pm
by aaron
as for your head/block combo the 2lt abf bottom end with 1.8 kr head is a popular combo, if you decide to use the 2ltr bottom end make sure you use the 2ltr distributor, for info on wiring looms and wiring conversion look up a chap called (rub jonny) on most VW forums clubgti etc, any thing he does'nt know about wiring is'nt worth knowing lol
Posted: Thu Dec 05, 2013 11:37 pm
by gplategt
aaron wrote:as for your head/block combo the 2lt abf bottom end with 1.8 kr head is a popular combo, if you decide to use the 2ltr bottom end make sure you use the 2ltr distributor, for info on wiring looms and wiring conversion look up a chap called (rub jonny) on most VW forums clubgti etc, any thing he does'nt know about wiring is'nt worth knowing lol
kool yea my last 1 had 2ltr block and 1.8 head(carb 8v) n gti cam, was still good but not what im after, it was rather flat, im looking at blocking injector holes and i need a quide on that lol
Posted: Fri Dec 06, 2013 6:40 am
by roccodave
as far as im aware the injectors are in the manifold so no need to block them like you would need to to run a 8v injection on a carb
