door handles
Posted: Sun Nov 24, 2013 4:55 pm
i suspect the answer is "no", but are mk1 and mk2 outside door handles interchangeable? or mk1 golf handles?
Re: door handles
Posted: Sun Nov 24, 2013 6:37 pm
by ianaudia4
I think they would fit, never tried but I have seen a MK2 Golf fitted with early chrome handles from
a MK1 Golf? For what you can pick them up it must be worth a shot!
Re: door handles
Posted: Sun Nov 24, 2013 7:31 pm
From memory there is two types of mechanism to the door handles, Mk1 Scirocco might have a differnet mechanism to the later door handles.
I think you can swop over the workings but not 100% sure.
Re: door handles
Posted: Mon Nov 25, 2013 3:21 pm
by PeteGLi
Mark 1 and Mark 2 door handles are not interchangeable as the locating lug on the front of the handles are a different design.
Re: door handles
Posted: Mon Nov 25, 2013 3:40 pm
Are mk1 golf ones ok?
Re: door handles
Posted: Mon Dec 30, 2013 9:25 pm
by The Autoad
Mk1 and Mk2 handles are not interchangeable sir. The mechanisms and locks on each are different.
Golf 1 used the same system as Scirocco until about 1978(ish) if i recall correctly. After that the design changed to the later handles and larger locks as per the kind used on mk2 Scirocco.
