ABF guide needed
ABF guide needed
Does Anyone know of a guide or good threads on seperating the 16v loom up and getting it running on Ce1 ? any and all info needed :) Thanks
Re: ABF guide needed
Club gti fella.
Think it was under engine electrical section. Failing ebay there's a install CD
This could help:
compare
http://www.a2resource.com/electrical/CE1.html
with
http://www.a2resource.com/electrical/CE2.html
CGTI thread:
http://www.clubgti.com/showthread.php?2 ... usebox-FAQ
post #5 Golf MK3, CE2 Fusebox
post #6 1984-89 MK2 Golf, MK1 Golf/Cabrio and Scirocco models from around 84 onwards, CE1 Fusebox
I would strip off all the tape on the Mk3 loom, cut out everything that isn't needed (eliminate using the resources above),
then use a pin tool to tidy up the loom if tangled, and then re-pin CE2 Mk3 wires from their Mk3 connectors into CE1 Scirocco connectors
compare
with
CGTI thread:
