okay so you may have read in my build thread that the rear valance under the bodykit has had a severe dose of the tin worm, from a chat over on the Facebook Page it looks like VW Heritage will supply a replacement, result, but for £400, bummer. They do however do a replacement MK1 rear section for about £25, a bargain if you ask me. Sooooooooo my question, probably aimed at those with lots of rocco building of both MK1's and MK2's (looking at you Autoad) how close below the bumper line is the profile between the MK1 and 2, ie could you make the MK1 valance section fit the MK2?
Obvioulsy the ends would be different but i'm looking at the main panel between them.
Heath
MK2 Replacement Rear Panel
Re: MK2 Replacement Rear Panel
Bit of a bump as there was some resent chatter on the Facebook page about this as well :)
Pics of the rear of non bodykittd cars both MK1 and MK2 would may be help to see if the centre lower secion could be used from the MK1 panel on the MK2 :)
