Since hooking up the Alpine head unit to the lovely amp what I got off of Jim-Bob, I've noticed that at higher volumes the back-lit buttons on the Alpine pulse in time with the bass.
This can't be right, can it? What have I done wrong?
Lights on head unit pulsing
- Big Bad Baz
Re: Lights on head unit pulsing
I've heard of some high-power Alpine units doing this. I think the answer is to run it's own +ve feed wire from the battery.
the wiring that runs to it isn't up to the job of powering it. you need to run a new (chunky) wire from the battery to the unswitched connection to the stereo, via a fuse fitted close to the battery
- Big Bad Baz
Thanks chaps, will get that done ASAP.
Love you long time.
Love you long time.
F668VBD - Gone, but not forgotten.
doesn't need to be as big as the cable used for wiring in amps. something roughly twice the size of the original should be more than plenty
- Jay4424
...i always use house-hold flexi wire (that used on extention leads!)
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
'52 BSA A10
'03 Suzuki GSX1400
