Play in strut top mounts
marcus
Post by marcus »
The last couple of MOTs on my 1985 Mk2 have had the advisory 'slight play in upper MacPherson strut mounting' or words to that effect.
It's nearly MOT time again so I'm thinking I should do something about it - anyone have any ideas as to the likely cause?
I'm hoping it's something as simple as tightening the spindle retaining nut but suspect it may be a worn bush or something...
1985 GTL 1.8
beekeeper
Re: Play in strut top mounts
Post by beekeeper »
you can MOT a car up to 28 days in advance and not loose any time on it.
might as well get it done first before you rush into spending money you don't have to.
theres always a bit of play in them anyway.
'80 scroc gls, '90 7' drop mk1 pickup, '95 5" drop works van, '91 sierra gt, '80 gs400 cafe racer, '78 yamaha bobber project.
some testers will advise of play in top mounts even when they're brand new, coz as said, they do have a bit of play in them anyway. are they knocking?
marcus
Post by marcus »
How would I know if they're knocking? The car is 28 years old after all, I don't know which bits 'should' rattle, and since I've had it for 10 years, I haven't noticed what's changed in that time? ;)
1985 GTL 1.8
marcus wrote:How would I know if they're knocking? The car is 28 years old after all, I don't know which bits 'should' rattle, and since I've had it for 10 years, I haven't noticed what's changed in that time? ;)
that's easy, nothing should rattle! top mounts that are deaded will normally give a soft knocking sound driving over rough ground or when you go over a bump on the road
marcus
Post by marcus »
Sorry to be dim but how I do I know a rattling sound is coming from the top mounts? How do the MOT testers determine there is play, can I reproduce that test myself to see what they're talking about?
1985 GTL 1.8
bengould
Post by bengould »
marcus wrote: can I reproduce that test myself to see what they're talking about?
Jack the front of the car up to take the weight off the wheels and try and wobble the top of the strut. I would say any more than a mm or so is excessive.
Ben.
marcus
Post by marcus »
I'm probably being dim, but where/how should I try and wobble the strut top, from inside the wheelarch by grasping the top end or by removing the strut top cover and trying to move the end? Or sticking a lever under the wheel?
1985 GTL 1.8
bengould
Post by bengould »
marcus wrote:I'm probably being dim, but where/how should I try and wobble the strut top, from inside the wheelarch by grasping the top end or by removing the strut top cover and trying to move the end? Or sticking a lever under the wheel?
Grab the top of the strut from inside the wheel arch.
Ben.
