Center consul help please
Dannyboyvw
Hi there I was wondering if the bottom bit of the dash with the gear hater and big cubby hole will the golf one fit with the vdo gauge mounts on I hope people no what I mean lol
Re: Center consul help please
Depends how you define "fit" I suppose! Probably easier to make a panel to fit
Dannyboyvw
Well I didn't want to make one lol when I say fit I mean take the rocco one out and golf in are they the same part but one with gauge holder and rocco with out
A quick and easy fix to allow up to 3 VDO gauges, is to use a VW radio blanking plate and drill out the holes for the gauges. This plate can be fitted where the ashtray and gauge blanking plate are located.
A few people have done this already.
I am pretty sure I have a VW blanking plate in my garage full of parts!
Dannyboyvw
That don't sound a bad idea good point how much would you want for the plate thanx dan
- dozzum
Ye I'm sure someone on here has done it and taken photos as they go.
If not then there is definitely an faq on the net on a random site I cam across while googliing.
I'll see if I can find it again.
Dannyboyvw
- go-for-it1
I have done the conversion so here is a link to my thread which might give you some help
Rob
http://www.sciroccoregisterforum.co.uk/ ... hilit=+vdo
Rob
2012 BMW 520d M Sport
2013 Golf TDi 140bhp
Member No 1241
Dannyboyvw
I just got one of these and bolted it to the bottom:
http://www.vwheritage.com/vw_spares_VDO ... tartRow=31
Hardly original looking but that's the least of my worries. Keep meaning to do the proper conversion but never got round to it
If you have could you let me know how much you'd want for it please?ianaudia4 wrote:A quick and easy fix to allow up to 3 VDO gauges, is to use a VW radio blanking plate and drill out the holes for the gauges. This plate can be fitted where the ashtray and gauge blanking plate are located.
Fitting instructions for guages where the ashtry is-
http://www.gakmotorsports.com/moreinfo/ ... epanel.htm
I'm currently looking at using a guage pod from a mk1 drop top and fittinf it under the radio, same position as Mr Funks, will post up a pic over the weekend as I;m looking at mocking it up :)
Will do Jim, I did offer it to someone but I've not had a reply.Mr Funk wrote:If you have could you let me know how much you'd want for it please?ianaudia4 wrote:A quick and easy fix to allow up to 3 VDO gauges, is to use a VW radio blanking plate and drill out the holes for the gauges. This plate can be fitted where the ashtray and gauge blanking plate are located.
