Low Idle When Warm
josh2109
Low Idle When Warm
Post by josh2109 »
Hi guys,
Car is doing what it says on the tin really - starts fine when cold and idles ok. However once it gets up to temperature the idle drops to 500 rpm or less :?
It was running fine until the other day. It had been standing on the drive for about a week or so, before I stopped using it she ran perfect, started her up the other day and the idle was mega low once warm. Nothing had changed so I don't really know what could be wrong.
My thoughts are fuel starvation or maybe a gunked up crank case breather (it's not blowing as hard as the one on my Golf). Is there anything else I can trouble shoot? The choke is wide open when hot and I've got all new vac lines from a few months ago. I'm a bit stumped :(
Cheers,
Josh
*edit
I should probably add, it's a 1.8 MK2 Scala on a Pierburg 2E2 (I know - boo, hiss etc.)
Re: Low Idle When Warm
Have you Tried increasing the idle speed when its warm and the idle is low?
gafr21
Post by gafr21 »
Hi, I have had a similar problem with my GTII only that the revs drop so low that it eventualy cuts out. Adjusting the idele speed screw on the cetal disk/plunger part does nothing (I have moved it while the car is running to the extreem and it has no effect).
Same carb, fine when cold.
Any thoughts? :)
