some help needed 3 questions
hi all
dragged the scirocco out and been looking over it, have a couple of questions
firstly bumper iron is rotten, have sourced a new bumper, so first question, how to get off
have noticed one large bolt that goes through crossmember ( fairly large bolt about 17mm to right hand side of cross member, but where is the other bolt?, thought there were 2 to get out either side
secondly head lamps, have the usual broken clips ( gsf 94333) which i have now got new, now these are the front clips as such , i have one at back of this screw which is broke ( circle with like 2 lugs coming off, anyone have one ? )
lastly because been sitting for so long battery is goosed tried giving it major charge but absolutely nothing, so new battery needed recommendations please ,,
1.8 gt2 ex engine h reg
help me get this scirocco back on road
- walkinginperu
Re: some help needed 3 questions
Battery-wise, I bought a Halfrauds Calcium one for my EW engined 1.6GT. Higher cranking power than the normal ones, makes it a hell of a lot easier to start in the winter!
front mate, as you look under the bonnet to the right of crossmember one big nut, screws left into bumper iron, meant to be two ? though i think, two holes in replacement bumper
Two bolts on each side - if you can find one, then go forward or back to find the other one. If you cannot find it, then it may have been left off sometime in the past.gt2 wrote:front mate, as you look under the bonnet to the right of crossmember one big nut, screws left into bumper iron, meant to be two ? though i think, two holes in replacement bumper
good point pete, will take another look
any suggestions on these headlamps clips, the ones at back ? any one got some spare,
need one perhaps two, going to fail mot so really need these , headlamp is loose
stick up a pic? i'll check my stash.gt2 wrote:good point pete, will take another look
need a couple of the back clips as in photo sean
note thats its for the headlamp not the inner lights they are slightly different
i have put a pic of both sides, left hand side has gone on mine
i picked up a secondhand battery from a breakers that looked nearly new for £10
looked in halfords and the same one is £58 only get one that looks newish if you do go secondhand tho
the date of installation/sale *should* be marked on most batteries. there's usually a whole load of years and 12 months printed on a sticker, and the year and month of installation will be punched outroccodave wrote:i picked up a secondhand battery from a breakers that looked nearly new for £10
New headlight clip posted yesterday Mike, first class - trust the postal strike doesn't delay/affect MOT.
