Wishbone Captive Nut
scalainj
Post by scalainj »
Hi
I cannot get my wishbone bolt to engage the captive nut in the chassis leg. It's possible though i cannot tell that the thread has stripped because the bolt has popped out.
Am i correct in assuming that to get to the nut i need to cut the leg? Any other options?
Andy
91 Scala
05 Alfa 156 Ti
06 Alfa GT
Re: Wishbone Captive Nut
Have you tried to get the bolt to go on the nut with out the wishbone there, just incase its not lined up, or try a longer bolt with the same thread to see if the nut has been stripped. If the nut is stripped you have to open up the weld on the leg and remove it.
There was a guide some where, I'll try and find it for you, but is major surgery to remove it.....
Here you go, I think you need a g-mail account to see it but not sure. (It came from Rubjonny on the Mk1 Golf forum.)
https://drive.google.com/folderview?id= ... b&hl=en_GB
If it does not go the the page its about half way down, a PDF file called "g1 front suspention repair" it's in there...
scalainj
Post by scalainj »
Thanks Mark
I have not as yet taken the wishbone off, that is the next job. I may if there is enough space try and recut the thread.
Unfortunately the link doesn't work
91 Scala
05 Alfa 156 Ti
06 Alfa GT
bensspares
Post by bensspares »
when removing that long bolt be i love ballet care full, if you strip or cross thread the nut thats inside the leg, big big problem...tip, before tightening, turn the bolt oposite to tightening to feel it in the thread.Follow haynes on this 1...
scalainj wrote:Unfortunately the link doesn't work
If you PM me your e-mail I'll send it to you. :good:
I've e-mail the pdf file, let me know if there is any problems with it. :good:
scalainj
Post by scalainj »
Thanks Mark
In the end once the wishbone was out i got a bolt into thus making my day as the nut was still good. Still was a pain to get to gether but the lesson learned here was do not try and put the wishbone bolt in when the both the anti roll bar is attached and the front strutt brace is tensioned.
So we are running and road legal - handbrakes cables and an oil leak to solve next
91 Scala
05 Alfa 156 Ti
06 Alfa GT
Glad I could help, at least you did not need to remove the nut in the end, looks major work and some thing I would not want to do..
