292 light on buzzer relay acting a little odd.
Posted: Thu Jun 27, 2013 1:29 pm
by bengould
Hi,
I have got a 292 buzzer relay for my car as I always forget to turn my light off.
Tested it out of the car and it buzzes fine.
Put it in the car and it doesn't work.
Have done a little messing and found that if I put my wipers on it works as it should. Lights on & no ignition it buzzes, but if I leave the wipers off it doesn't work at all. It also makes a loud buzz if I put the wipers on slow or fast, but makes a quiet buzz if I put the wipers on intermittent.
I am using a 99 relay for my wipers if this makes any difference?
Any ideas why anyone?
Ben.
Re: 292 light on buzzer relay acting a little odd.
Posted: Thu Jun 27, 2013 2:38 pm
by Old Mac Rocco
:hi: :buddy:
Had a quick look at my fuse box and can't see a 99 relay anywhere.
These are the only ones fitted to mine.
I also had a look in the spares dept and came across these.
Funny how only three of my spares match up with what's in the fuse box ???????
If there is anything here you may need or want to try drop me your address in a PM and I'll post it down to you.
Good luck.
Posted: Thu Jun 27, 2013 2:46 pm
by PeteGLi
Old Mac Rocco wrote::hi: :buddy:
A 99 relay would replace the 19 relay in the fusebox, and give the variable intermittent wiper function.
I believe others on here have tried the lights on buzzer relay, and found it does not work properly in our cars, as they were not designed for them. A search may reveal more info, as I recall the subject being discussed at length. Assuming the topic was not on the previous forum.
Posted: Thu Jun 27, 2013 2:50 pm
I would guess that it needs an earth that it doesn't have, and by leaving the wipers on it is managing to earth through them somehow. Easiest way to wire in a lights on buzzer is to take a live from the sidelights and a switched earth from the drivers door. This won't tell you when you leave the "parking lights" (one side of the sidelights, switched by the indicator stalk) on though
Does your 292 relay have a wiring diagram printed on it?
Posted: Thu Jun 27, 2013 9:35 pm
by Risocco
Interesting, my 292 works A-OK.
Believe it replaces the fog light relay?
Posted: Thu Jun 27, 2013 9:45 pm
by bengould
Nate wrote:Does your 292 relay have a wiring diagram printed on it?
No, Just part numbers and numbers on the pins.
Nate wrote:Easiest way to wire in a lights on buzzer is to take a live from the sidelights and a switched earth from the drivers door......
That might be the next course of action, Have got a relay holder to clip to the top of the fusebox so might just end up wiring it in that way.
PeteGLi wrote:
I believe others on here have tried the lights on buzzer relay, and found it does not work properly in our cars, as they were not designed for them......
As far as I remember the only issues people had was that the fog lights don't work with this relay. Will have a search though and see what I can find.
I have some 99 relays for sale if you want one to replace your 19?
They are on ebay at the moment but will be adding to the for sale section in the near future. PM me if you want one though.
Risocco wrote:Interesting, my 292 works A-OK.
That's interesting, I have it in place of the fog light relay, position 7 in the fusebox. :dunno:
Good to know they 'can' work.
Ben.
Posted: Fri Jun 28, 2013 11:58 am
by bengould
I appear to have fixed it.
Turned the front fog lights on this morning and when I turned the ignition off, it buzzed.
Turned the fogs off again and now it works as it should.
Slightly confused but it works.
Ben.
Posted: Sat Jun 29, 2013 10:08 pm
by dozzum
I wired a buzzer in from both side lights via diodes then earthed it through the drivers door switch. This stops me leaving any sidelights on including the parking lights from leaving the indicators on.
Posted: Sat Jun 29, 2013 10:18 pm
Why thru diodes? I suspect I'm probably being a 'tard and missing something blindingly obvious
Posted: Wed Jul 03, 2013 11:54 am
by dozzum
Otherwise leaving the parking light on on one side would feed across to the other parking light.
Posted: Wed Jul 03, 2013 11:56 pm
told you i was being retarded
