Screw / Bolt numbers
- whiteshark
I put on an armour door plate today and I needed to swap one of the barrels on the drivers door lock. The screw/ bolt that secures the handle on the outer right side of the handle needed drilled out as it wasn't budging. ( Despite several soakings of WD40 from the outside and inside after removing the doorcard.) What screw / bolt number is this and is there any type that doesn't rust up as much?
Re: Screw / Bolt numbers
The bolt part number is N0141313 and the spring washer is N0122224.
These are the bolts that are on the opposite end to the lock!
