Suspension Bush Renewal
Posted: Tue Apr 16, 2013 10:06 am
Morning all,
I'm going to be fitting a new suspension kit in the coming weeks, and whilst I'm under there I figured it would be a good idea to renew all of the suspension bushes at the same time. I'm just trying to get an idea of what I need, where to get it, and how long it's likely to take to complete the job.
So, from the front to back, I'm intending to replace the front wishbones (and bushes), front ARB bushes, rear ARB bushes and the rear axle bushes, as well as replacing all top mounts on the suspension. Anything else I should consider doing at the same time?
Having read a bit about my options, I'm planning on using standard rubber throughout rather than polybushes, since the car is used primarily on small roads and around town, so a more forgiving ride is probably best. I understand I can still get the rubber bushes direct from VW, is this still the case?
Any ideas on how much time I should anticipate this taking? Anything specific that might be a pain in the rear?
Thanks in advance - sorry for all the questions!
