You can see the gap with a small spline wheel fitted, Should there be a spacer there as in the Haynes for earlier cars? could I cut the removed adaptor to that size to make it a spacer?
I would like an earlier Scirocco wheel but might try this Polo one I have lying about, anyone had any success fitting such a wheel?
I am also hoping to fit these steering bellows when I fit the column now I have a heat shield on the downpipe, just want to be prepared for any issues
