First things you would do after buying a Mk1
Posted: Wed Mar 20, 2013 4:58 am
Alright guys, you might notice that I'm going to be a bit more active on here since actually being in the financial situation to be able to buy a mk1 scirocco!
(viewing on Sunday and hopefully buying too so long as its good enough!)
I'm not asking about mods etc, but I would like to know the first things you would do to a new (to you) mk1?
I know the rocco had brakes, wheel bearings, brake lines, fuel lines, fuel filler and a few other things replaced last year for the MOT.
All fluids, filters, plugs, belts go without saying... (timing will also be verified using a very handy guide i found online)
maybe shims for the tappets? again i found a guide so i will be buying some feeler gauges and a new type non-cork gasket ;)
I would also like to check the afr to ensure the k-jet system is running correctly so some time soon I'm going to have to bribe someone local to help me out there ;)
but what about injectors.. can you still get new ones? because they've only got a recommended life of 60,000km according to Bosch.
I'll also be sticking a flash light in the tank just to check if there is any clogging or rusty bits in there.. (seeing as the fuel filler pipe was replaced)
I'll be looking to get some new tyres as i feel the ones on it at the mo are a bit old... any recommendations? its got both a set of GLI alloys and some mk1 steelies too..
both 13" 5.5J (wagon wheels!) I'll be looking to put the alloys on it, but what tyre size is correct? (or at least recommended by you guys?)
I see 155 sr 13.. (aspect ratio?) and 175 sr 13 (again whats the correct aspect ratio?) on the original documents scanned in on the tech specs side of the site.
(I also have a PDF bentley manual for the mk1 golf cabbie and mk1/2 scirocco inc 16v)
anything else i should be considering?
Cheers guys
Lew
(yes a very odd time to post but unfortunately due to university I am indeed now nocturnal
Cheers guys
Lew
