Part number for 1982 mk 2 speedo
Don't know German? look here
As title, can anyone find me the part number for the mph speedo for a 1982 GTI? This is a 120 mph speedo with no cut-outs for ancillary gauges.
Blueshark
Re: Part number for 1982 mk 2 speedo
Post by Blueshark »
Part number should be 534 957 803 RHD length = 1860MM
Grts, Joost
No, not the speedo cable, it's the gauge I'm after (speedo in mph + odometer/trip). Thanks, though.
Blueshark
Post by Blueshark »
the edmundator wrote:No, not the speedo cable, it's the gauge I'm after (speedo in mph + odometer/trip). Thanks, though.
O sorry, read it wrong.
I can not help you with that because the numbers are no longer available, the part as been obsolete for so many years they do not even bother of mentioning it.
I can not help you with the part either because I only have KMH dial in stock.
Joost
Curse you and your km/h!
Blueshark
Post by Blueshark »
the edmundator wrote:Curse you and your km/h!
Why :hehe: because |I have about 15 in stock or because we all have it over here on the mainland. :laugh:
Joost :bye:
Both!
