Alternative Clutch for 1990 Mk.2 Scirocco
BagPuss
Post by BagPuss »
Afternoon,
Anyone know what clutches are available for a Mk.2 Scirocco Scala on a DX Engine Code?
I have a Sachs Clutch in at the moment, but looking for any alternatives as I'm changing the gearbox from a 020 5 Speed AUG to a 020 4+E ATH.
Demon Tweeks listed I think 7 Clutches, which said Call for Price......yet, they don't stock any of the ones they listed????
So that was a complete waste of time calling them?
Anyone know of any others or am i limited to VW & Sachs?
Cheers all,
Re: Alternative Clutch for 1990 Mk.2 Scirocco
luk clutches
i would be very reluctant to put a racing clutch in a rocko just on the basis that the baulkhead is going to be even more likely to pull through if you havent allready beefed it up.
actually thinking about it, im currently taking an abf lump apart and what would sop you putting an o2a gearbox on a 1.8 dx engine and utilising the bigger hyraulic clutch setup?
and you cpuld have cable operated gear shift
BagPuss
Post by BagPuss »
Thanks,
Never had a problem with the bulhead but have got bulkhead support bracket to go in, so that will help.
Gonna look at Black Diamond, Luk and Helix.
Going from 150BHP to around 200BHP+ in bursts :hehe: but I don't think the Sachs Clutch will be up to it, so if I'm changing from the 5 Speed to the 4+E, I might as well change the Sachs clutch I've got in there to something a bit more beefy.
marcus
Post by marcus »
Never had a problem with the bulkhead?! You must be the only one, or has yours led a really sheltered life? :)
1985 GTL 1.8
No, I've never needed to reinforce the bulkhead either.
BagPuss
Post by BagPuss »
Well it does lead sheltered life now, but it's done 168,000 so far without any problems with the cable pulling through :)
Mrgarf
Post by Mrgarf »
id go for a clutch that will be up to your plans(as in uprated sachs something like that), reinforced bulk heads not heard of that before?
1984 vw scirocco gl finished in pink
2004 Vw bora highline
2020 Jaguar e-pace checkered flag
