Help with heater blower
Crewie77
Post by Crewie77 »
Hi
Replaced the fuse box after the usually water leak.
But since I stripped the dash out the heaters don,t work tried fuses have not blown cleaned the rear connection but when I check the readings with a multi meter there is no reading so need so help please.
Adam
Re: Help with heater blower
Has the cable become detached, no power would indicate this?
Crewie77
Post by Crewie77 »
Did some work yesterday regarding my blower. I now have power to my fuse board. To the back of the switch and then to the resister and then to the fan motor.
But it does not turn have turned it by hand but it feels very stiff.
So it must be the fan motor so what the best thing to done can it be replaced. Or can it be repaired and how much of a job is the removal of it.
Adam
