Filler neck
Posted: Sat Jan 05, 2013 7:36 pm
Is there i difference between filler necks for siroccos with full size spear wheel or space saver?
Thanks paul
Thanks paul
The official forum for the Scirocco Register
https://forum.sciroccoregister.co.uk/
Thanks I will size it up when it arrives I got it of eBay the chap said he had it for years warped up in his garage . If its the wrong one I will post it up for sale on hereianaudia4 wrote:The Scirocco with the larger 55 litre tank has a filler neck about 100mm shorter at the tank end.
Thanks not thought of thatianaudia4 wrote:You can fit the longer version to a later car by cutting off about 100mm at the tank end.
Ok thanks I will let you know it should be with me on Tuesdaythe edmundator wrote:Or sell it to someone like me who only has the small fuel tanks and can't get a new one from VW.
I have a spare filler neck (for my own stock) which I think is the shorter version - I'd be happy to swap if you ended up with a longer one.
