heater matrix
gtx 1986
heater matrix
I have a leak on my pasenger side checked seals drains sunroof no leak think it might be matrix cas it only there when a start it up and take it for a run and its got a inch of water in it my radiator tank does not have antifreeze in it
Re: heater matrix
Fairly straight forward to change if a little awkward. You should be able to pick up a new matrix for around £30 and fit within a couple of hours if not sooner.
Make sure you refill your coolant with anti freeze, these cars were designed to run with G11 which is blue and doesn't mix with G12 (pink).
Re: heater matrix
Should have a spare from the Monza if you want it
