which way?
Posted: Mon Nov 12, 2012 9:04 pm
by thehat
i got my gt2 cheap as it has no history and ten owners!!so bearing that in mind,should i make it as original as is possible and just restore it,even though it would never be all that desirable,or stick in a vr6,and just go for the street sleeper look.i dont really like the kitted up look,so maybe 30 to 40 mm drop and a bit of performance with the vr6? all veiws are welcome.thanks,thehat
Re: which way?
Posted: Mon Nov 12, 2012 10:23 pm
by the edmundator
VR6 isn't the best engine in a scirocco as it's heavy and will ruin the handling - fine if you just want to go quick in a straight line. Yours sounds like the kind of car you can do what you like with, preservation/restoration best for the low owners, low miles, full history cars and rarer models.
Re: which way?
Posted: Mon Nov 12, 2012 10:39 pm
by The Autoad
Ed is right, the VR6 is not the best powerplant for a light Scirocco. For my tuppence, i'd keep to the spirit of the car and drop in a 2 litre 8v or a 16v lump.
Re: which way?
Posted: Mon Nov 12, 2012 10:47 pm
by bengould
Unless you wanted to go mental and put the VR6 in the back.
But I'd go as suggested or 1.8 20v turbo
Ben
Re: which way?
Posted: Mon Nov 12, 2012 10:49 pm
by thehat
many thanks,think i will do the 16 valve,and ya dead right about the vr6 upsetting balance.hang on,vr in the back?
Re: which way?
Posted: Mon Nov 12, 2012 10:51 pm
by bengould
Think mid-engine RWD. :-)
Probably more work than its worth but would definitely be unique.
Ben
