Cleaning the interior of lights
Posted: Fri Oct 26, 2012 5:17 pm
by SYNCRO
Need to clean the interiors of the two inner heaflights as the glass appears to be slightly milky/dirty.
What is best method. Also need to refurb 2 underbumper driving lights with the same problem. TVM
Kev
Re: Cleaning the interior of lights
Posted: Sat Oct 27, 2012 12:09 am
by MacColl
This guide is for Mk2 Golf lights, pretty extreme taking them apart. I am sure someone with patience had cleaned them without taking them apart with soapy water, clean rags stuffed in and then a hair-dryer. Too much aggressive cleaning and/or cleaners might remove the chrome I suppose
http://www.vwgolfmk2.co.uk/viewtopic.php?f=37&t=2917
Posted: Sat Oct 27, 2012 6:07 pm
by SYNCRO
Cheers for that.
Cleaned on today. Started off soaking the lense unit in a diluted vinegar mix.then agitating with a small paintbrush. Was surprised how much muck came out! Rinsed them out with demin water to avoid streaks. Dried them off in the oven as it was still warm baking earlier on.
Dremilled the mounting primered then sprayed satin black. Rub plastic restore into the faded plastic and they are like new now!
Posted: Sat Oct 27, 2012 6:51 pm
by mr.brown
Nice one! But you do realise that without pictures it didn't happen
Posted: Mon Oct 29, 2012 9:51 am
by SYNCRO
This is the old version, I'd already made a start on restoring the plastic bodies which were a pale grey iso black.
This after cleaning and respraying the mounts....... just noticed there's still a bit of adhesive from the masking to clean off!
I'm still doing the second one which will be held as a spare
Posted: Mon Oct 29, 2012 4:01 pm
did some audi lights and my caddy by removing the glass and popping them in the dishwasher (don't put the reflector in the diswasher!)
Posted: Sat Mar 23, 2013 1:50 pm
by roccoGTX
You've shown the fog lights. not the inner headlights on your pics.
Can you clarify, esp about the dishwasher!!
John
