carbs
foylie
carbs
Post by foylie »
Hi hoping someone may be able to help out here, i am currently running a mkII 1.8 8v on twin 40 dellortoes but carbs seem a bit unreliable and i was hoping to replace them with a set of bike carbs but after speaking to the very helpful guys at bogg bros have been informed this is not a good idea because of the laid back engine and also lack of space between engine and bulkhead, does anyone know of a better alternative that will get car running better
Bonusrocco
Re: carbs
Post by Bonusrocco »
Throttle bodies by jenvey or weber (alpha) with custom management, but its very pricey 2-3k. Having carbs tuned properly requires a rolling road, theres a few places dotted around that will do it. Best bet perhaps - find the injection setup from a standard 8v. that would be cheap easy to find and reliable then
So many plans, so little time
wassell
Re: carbs
Post by wassell »
for reliability, bike carbs are very simple as they never fall out of tune like the webers. however, as mentioned by bogg brothers there isnt much room back there and they are a tight fit. but it can be done.
i never seemed to have a problem with the standard (well, standard replacement from the OEM pierburg) 32/34 dmtl weber carb fitted to my 8v engines. it'll be less responsive than the twin 40's (and wont have that amazing induction roar)but will most likely give you a lot better mpg and reliability. you can also pick them up fairly cheap, and selling your twin 40's could easily pay for the conversion.
as mentioned previously, you could convert the car to injection. would require a different head ( about 50 pounds, but may not need one if you're running the DCOE manifold that does not blank the water outlet on the back of the head. this water outlet isnt present on the GTi heads, only the carbed heads to prevent carb icing) and a higher pressure fuel pump (about 60-100 pounds new) aswell as the inlet manifold/throttle body/injection set up and ecu. probably easier to take it all from a car being broken.
if money was tight, and the twin 40's were causing a lot of grief, and you have had them set up properly previously, then i'd look at going back to the 32/34 dmtl set up. its just a very simple and effective carb set up.
hope that helps.
tom
foylie
Re: carbs
Post by foylie »
Thanks very much for the good advice and i will have to decide which way i am going maybe a twin choke weber. did,nt want to go there but for smooth runnings sake may have to thanks again
Eurobox
Re: carbs
Post by Eurobox »
Just for you to bear in mind I've got a twin choke Weber 32/34 dmtl in the garage jetted for a 1.8
£100 delivered
1991 Scirocco GT 16v - daily go kart
2004 350Z GT - weekender
2015 Qashqai Tekna - shopping trolley and taxi
foylie
Re: carbs
Post by foylie »
Hi just a couple of questions before i take up your offer does the carb fit onto a standard manifold or is it a special reqd also is it a case of bolt on and go or would it need a refurb thanks
wassell
Re: carbs
Post by wassell »
just for some more info bud
unless it comes with the manifold etc, youll need a manifold which looks like this:
if you did the conversion from a carbed engine, you'll hopefuly have the right manifold left over (presuming you removed it in the first place). the most important thing is the water outlet on the head though, you need to check if you have this or not (GTi head wont have it). if you do have a carbed head, with the waterway, you'll need a genuine manifold with the waterway on the manifold. if you dont have the water outlet on the head, any manifold will suit (such as pictured which doesn't have the waterway).
for reference, heres a few pics
GTi head, showing inlet and outlet ports, but no waterway
genuine carbed manifold
foylie
Re: carbs
Post by foylie »
Still have the manifold from the pierberg carb set up so hope this will do thanks
wassell
Re: carbs
Post by wassell »
yeah that'll bolt to either head, if you've got the waterway (which you probably do if it were originally carbed) then thats better anyways as it'll help prevent carb icing. keep an eye out for the water hose that you'd have removed though, you'll be needing that to return the water from the manifold back to the system.
Eurobox
Re: carbs
Post by Eurobox »
foylie check your pm's!
