installing rear side windows on mk1 scirocco
Posted: Sun Jul 08, 2012 5:00 pm
by malmac
Hi,
bought new window riubber for n/s/r window and it's really difficult to fit.
I've put the string around the rubber seal but when i come to pull it whilst sitting inside the car to fit it, it pulls too much of the rubber seal through every time.
It's a 2 man job but neither of us are having any luck.
Any ideas???
Re: installing rear side windows on mk1 scirocco
Posted: Mon Jul 09, 2012 10:36 am
by james butler
are you lubing up the rubber enough to push it deep into the body 1st?
Posted: Mon Jul 09, 2012 12:07 pm
^^ what he said
use a bit of silicone lube from a plumbers merchant or some ky jelly. many people use washing up liquid, but it does have a high salt content, so wouldn't be my preferred choice.
Posted: Mon Jul 09, 2012 6:00 pm
by malmac
i've been using a spray on grease so would have thought so, i'll try some of the other suggestions though, as i'm all out of ideas here.
Trouble is, i'm not sure where i can purchase 'KY Jelly' as never used it before !!!
Posted: Mon Jul 09, 2012 6:35 pm
chemist or supermarket. you should use it, it's amazing stuff. best thing i've found for pressing in suspension bushes [/euphemism]
obviously other brands are available, but any water based personal lubricant will do. for ages i had a pot of "dr johnson's anal lube" in my toolbox. got some really strange looks of customers when they saw it
Posted: Mon Jul 09, 2012 6:44 pm
by malmac
ha ha ha, this is more like a "carry on" link than anything else. I've heard of people loving their mk1's but Dr Johnsons Lube ??????
Thanks for the advice, i can't do much worse.......i'll let you know if i'm successful .
oooooooooooo matron........................
Posted: Mon Jul 09, 2012 7:27 pm
also, wind the string round the rubber a good few times. gives you more than 1 shot at the seal going in right without having to take the glass out again
Posted: Tue Jul 10, 2012 8:55 am
by polov8
Glass cleaner is the preferred lube as it helps it go in, but then evaporates once the seal is in place, so you don't end up with them trying to pop out again.
