Got in the car this morning and the interior mirror has just dropped off!
It's not broken, all intact, just a little rectangle of clear sticky plastic on the windscreen where it used to stick.
What's the best way of reattaching? I've tried those sticky pads from Halfords in the past but they weren't that great IIRC.
Me rear view mirror dropped off!
Re: Me rear view mirror dropped off!
The loctite stuff which has mesh that you cut to size and add a liquid bonding agent to is very good. Detach the mirror from its metal mounting before you stick the mount to the screen, so it can stick properly.
Brilliant cheers mate - I did see that in Halfords so I'll give it a shot.
- dozzum
Used that stuff on mine and even though I have hit my head on it numerous times its stayed strong.
2pack mirror glue is the way forward. mounted my satnav with it. loads heavier than a mirror and stays stuck no matter how hot the van gets
This happened to me when my son got in the car and bashed his head against it.
I've tried the suction pad mirrors but they are not very good.
Thanks for the advice - I'll try it.
It worked a treat for me - the mirror's still on anyway!
I used the little mesh and glue last week when my mirror fell off, stuck firm now.
Best the clean the windscreen with white spirit to get all the old residue off.
