Matching springs and dampers
Posted: Fri May 18, 2012 9:33 pm
A few years ago, I fitted Boge Turbo gas dampers to my Scirocco. At the time, I was running standard GTX springs that offered a slightly lower ride height compared to the springs that carb Scirocco's ran.
Ride was a little harsh with the Boge dampers.
Now, last year, get pulled up on the MOT for having a couple of cracked springs. VW couldn't supply me with anything and I avoid £45 eBay lowering kits like the plague! Ended up fitting an Eibach prokit. Lowered the car another inch lower than a GTX. Has the tracking and camber reset. The ride is now poor on potholed roads and over speedbumps. It's acceptable on the motorway.
People talk about matching springs and dampers. Are the Boge Turbogas and Eibach prokit not going to work in harmony? Can anyone recommend a damper that will work well with my new spring? I've just invested in a pair of Eibach anti roll bars and will be rebushing the suspension along with a new rack, steering arms, track rod ends, ball joints and top mounts next weekend. I've spent a bloody fortune but don't want to compromise my efforts if there's a better affordable damper out there!
My other car is a Lotus Elise (Bilstein Dampers and Eibach Springs from the factory) and the ride quality is ten times better than the Scirocco. If anyone can help me 'flow' down the road, I'd be most grateful!
Thanks in advance for any hints and tips!
