camber bolts
jon89gt
camber bolts
Post by jon89gt »
anyone know where you can get camber adjusting bolts from??
thanks jon
thebrief_1979
Re: camber bolts
Post by thebrief_1979 »
Had this prob a week ago - had to get them made - apparently vw stoped doing them 2 years ago and gsf don't do them.
I recon vw heritage will have them though
1993 MK2 Flash Red GT2 - sold
Mk1 gls - nearly
Bonusrocco
Re: camber bolts
Post by Bonusrocco »
Are they necessary? is it possible to just use normal bolts?
So many plans, so little time
Re: camber bolts
yes, they are. the holes are slotted and it's the off centre head that keeps things stationary.
other VWs have adjustable camber, do they use the same bolts under a different part number? worth a look if you can find an EPC anywhere...
