Removing moss from seals
Joe87
Post by Joe87 »
My window and sunroof seals have a persistent moss growing on them that comes back after a few months every time I scrub it off. Anyone know of a decent product that will remove it and stop it coming back?
1987 GTX
MacColl
Re: Removing moss from seals
Post by MacColl »
I think I would go for a soft toothbrush and a non wax car shampoo then use that Auto Glym rubber and vinyl care, great stuff for rubber.
I've often thought that a mild bleach solution or even Milton might be a way of sterilising the moss growth but I am not in favour of household products because they tend to have a high salt content or are simply too aggressive. Someone else might confirm a trick or two.
normally a toothbrush gets it off fine. don't have a problem with it coming back so long as the car is washed regular
Nate wrote:normally a toothbrush gets it off fine. don't have a problem with it coming back so long as the car is washed regular
agreed - this is what i did on the gtl after its 9 year lay up.
81GTi
Post by 81GTi »
a wipe with vinegar will prevent moss and algea growth.
Neillyboy
Post by Neillyboy »
81GTi wrote:a wipe with vinegar will prevent moss and algea growth.
x 2
Joe87
Post by Joe87 »
Thanks for the advice. Will try vinegar applied with a toothbrush! I've always had problems with moss coming back after being cleaned off in three and a half years of owning the car. Makes it look so tatty...
1987 GTX
sick nick
Post by sick nick »
diluted weed killer??
sick nick wrote:diluted weed killer??
potentially has salt added as a bulking agent (like washing up liquid) so would promote rot. check the label, and so long as there's nothing in it that would harm steel, should be fine
