Wishbone Poly Bushes
Risocco
Post by Risocco »
Hi all, just after any experience you guys have of doing the above? Car in question won't be going near a track any time soon, just daily duties, depending on MPG of twin40s :blush:
Chassis already has Coilovers, Poly Bushed OEM Anti Roll Bars and 3 Strut Braces. Would guess its lowered around the 60mm mark? Wishbones are certainly inverted anyway. In the future, looking to go a touch lower too.
Also run 15" 7j wheels on Toyo Proxies.
So, is it overkill to poly them? Would the ride become more crashy? Worth it for increased cornering grip?
Cheers for any input :beers:
Jay4424
Re: Wishbone Poly Bushes
Post by Jay4424 »
I've done it, with a drop of around 100mm.. the rides fine!
..i drove a mates astra the other day, i was so happy to be back in my rocco, where i could feel the road and what was going on with the car-road interface!!!
..infact, I'm on similar wheels, only the two struts though, polyied EVERYTHING bar the engine mounts atm, this summer, unless some one buys it first, the roll cage will be going in :-)
'52 BSA A10
'37 72' wooden narrow boat
'03 Suzuki GSX1400
Chaps
Post by Chaps »
I have a set on mine, they are pretty easy to do with a vice. Ive not driven on them so cant say what they are like.
If you decide not to ge them and just replace with standard ones, i have a new set of wishbone bushes you can have for £10. Bought them before I decided to get poly ones.
Risocco
Post by Risocco »
Thanks for the input fellas. :beers:
Chaps wrote:i have a new set of wishbone bushes you can have for £10.
Ta for the offer mate, but if I do go down that route I'll get some wishbones with bushes in place so I can get them powder coated. Was thinking about seam welding them too but read far too many horror stories.
Chaps
Post by Chaps »
You will melt the bushes if they are in when you powder coat the wishbones. I found that when I powder coatedy engine mounts. All the rubber perished.
I've done it. Stripped the wishbone and had it powdered.
Cracking ride
Brunty
Post by Brunty »
Risocco wrote:Was thinking about seam welding them too but read far too many horror stories.
Really? Mine are seam welded. What horror stories?
Brunty
Chaps wrote:You will melt the bushes if they are in when you powder coat the wishbones. I found that when I powder coatedy engine mounts. All the rubber perished.
i'll 2nd that. the item being coated gets heated, not good for bushes
Risocco
Post by Risocco »
From what I've read, the reason they are spot welded from the factory is upon impact they will break/twist rather than twisting the chassis. Granted its not really an issue on a track car but on a daily that would suck.
do you mean continuous seam welded? coz i was sure the ones i've fitted in the past were partially seam welded
Risocco
Post by Risocco »
Nate wrote:do you mean continuous seam welded? coz i was sure the ones i've fitted in the past were partially seam welded
yeah, sorry, basically they are designed to break before the chassis does.
Jay4424
Post by Jay4424 »
Risocco wrote:Thanks for the input fellas. :beers:
I've got my polybushed, seam welded wish bones for sale mate ;-)
'52 BSA A10
'03 Suzuki GSX1400
