how to replace rear anti roll bar clamp help please
Posted: Fri Dec 09, 2011 2:06 pm
by traindriver69
Hi all
I am trying to put a new rear anti roll bar clamp on my mk2 rocco as the old one was missing,the problem i am having is how is the best way to clamp the clamp tight enough so that i can place the clip over the end.
i have tried a few different ways of clamping it but with no luck.
any help please
Re: how to replace rear anti roll bar clamp help please
Posted: Fri Dec 09, 2011 8:23 pm
by Mr Funk
The big oval one?
An utter c*** of a job, by far the worst I've attempted. First off remove the rear beam, it'll be ten time easier as you can use a vice. Don't use a cheap one though, as my build thread shows it'll Borrick anything that isn't up to it
Posted: Fri Dec 09, 2011 8:26 pm
by Old Mac Rocco
Posted: Sat Dec 10, 2011 11:13 am
by traindriver69
thanks for the replys dont fancy trying to drop the rear beam got to try and find something i can use while it is on the car.
Posted: Sat Dec 10, 2011 4:24 pm
by Mr Funk
Removing the beam is easier but not essential. Just try and get the car as high as safely possible and use a vice. Do it nice and slowly and you should be fine.
Good luck, you'll need it
