electronic fuel pump mounting...
YEAH
Post by YEAH »
iv got a "facet fuel pump" that needs mounting up as soon as really, just need a bit of advice as to where is best to mount it. should i tuck it away in the back of the car somewhere near the fuel tank or right up frount in the engine bay some where near the driver's side chassis leg?
anyone else have one fitted?
and if so, where's best?
twin dellorto 40's
black sebring's
stripped rear
roccodave
Re: electronic fuel pump mounting...
Post by roccodave »
i fitted mine on the driverside inner wing just after the filter then read the instructions that said to fit close to fuel tank
i havent had any problems yet and its been there for over 6 months
MrD
Post by MrD »
Mine is in my spare wheel well :hugegrin:
roccodave
Post by roccodave »
MrD wrote:Mine is in my spare wheel well :hugegrin:
then where is your spare wheel?
MrD
Post by MrD »
In my shed ! :hugegrin: Got a can of that gim you spray in if it goes flat.Also carry a plug in compressor,takes about 10 mins to pump up a tyre though,was only a cheapy from market
YEAH
Post by YEAH »
i think i will go for the inner wing option out of simplicity.
however.
got the car fired-up for the fist time on friday night sice fitting the carbs and the head. we got it going with the original crank-case lift pump. im not gunna keep it with that, obviously, will fit the facet in the week.
but, oh god did it sound awesome :cool:
twin dellorto 40's
black sebring's
stripped rear
