IGNITION SWITCH
Posted: Thu Oct 20, 2011 3:26 pm
by foylie
HOPING SOMEONE OUT THERE WILL BE ABLE TO ADVISE ME ON HOW TO REMOVE IGNITION SWITCH FROM THE STEERING COLUMN** ONCE I HAVE THE STEERING WHEEL REMOVED I AM UNABLE TO REMOVE FLANGE HOLDING IGNITION SWITCH ONTO COLUMN** DO I HAVE TO REMOVE COLUMN TO PRESS FLANGE OFF THANKS IN ADVANCE REGARDS FOYLIE
Re: IGNITION SWITCH
Posted: Thu Oct 20, 2011 4:05 pm
by mr.brown
CAPS LOCK STUCK?!!
To remove the switch, the manuals say you don't need to remove the column but it is easier with the column out.
Basically you need to remove the shroud from the top of the lock housing and drill a 3mm wide hole (downwards) in a very specific spot - which then gives you access to a retaining spring. Press down on the spring with a pin and you can then slide the switch out.
Very difficult to describe - really needs a picture. If no-one pipes up with one, I'll scan it for you.
*there's a How-To on this very site for removing the whole thing :hugegrin:
http://sciroccoregisterforum.co.uk/faq/ ... ring-lock/
