Rear seats, bench V split, interchangable ?
ghost123uk
Post by ghost123uk »
Hi all.
Simple question and I think I already know the answer, but just checking.
Are bench type rear seats interchangeable with the split type? (I reckon they are, am I correct ?)
Wanted by the way, front seats or a full set, in good nick, rare as... I know but... :beg:
PeteGLi
Re: Rear seats, bench V split, interchangable ?
Post by PeteGLi »
The seat backs have a different fixing as the split seat has a plate in the middle, to fit onto four studs that are welded into the vehicle body.
wassell
Post by wassell »
i took out my split and fitted bench. no hassel, just dropped right in there. cant say what would happen if you went the other way though
wasted
Post by wasted »
The previous owner of mine switched from off-centre split rears to centre-split, by taking the central support plate off his old scrapper and rivetting it into the floorpan. It's a bit wobbly really, because there's not much metal there... Need to take the fuel tank out at some point and put some proper reinforcement in there, or alternatively take it out and fit original seats back in. Or just remove the rear seats entirely and replace with carpet...
