throttel cable
throttel cable
Have had a few old vw in the past and neverhad this problem, my gt2 's throttel cable is stiff as ****, could this be the cable or wrong return spring on the carb, the routng seems fine,
Old Mac Rocco
Re: throttel cable
Sounds as if the throttle cable is being pinched somewhere along its length.
It should run really freely.
Have a look on here to see the spring set up if it is a weber you are running.
http://sciroccoregisterforum.co.uk/carf ... box#p77478
Re: throttel cable
am running the std carb, will have a good look tomorrow
Re: throttel cable
A new cable is pretty cheap, about £12 from GSF. Worth taking a look at the bush on the pedal, these perish over time, about a fiver from the dealers.
Re: throttel cable
thanks guys , all sorted now .. was cable tied to a load of stuff. freed up and good old WD 40
