Setting up Gears
Risocco
Setting up Gears
Post by Risocco »
Hey guys, since refitting the engine and box, its almost impossible to find 4th and to be honest, the rest of the gears hardly inspire confidence in terms of selection. Before the swap, the gear change was mint on my car, is there a tried and tested way to set up the linkage so I can get that back again?
Cheers guys, any help really appreciated :beers:
Re: Setting up Gears
Me and Tony set up the gears on a car at the Durham show last year. We used a 15mm socket as a gauge then tightened up.
Risocco
Post by Risocco »
Right-o, how do you mean as a gauge sorry? Where does the socket go? As you may have guessed this has really got me stumped!
Get an assistant to sit in the car whilst you are underneath and hold the 15mm socket against the gear stick and push to the left until it is held there, it can be quite tricky, then tighten, basic but works!
Risocco
Post by Risocco »
Ahhhh, cheers. On the to do list for tomorrow :good:
Good luck mate.
Tim_R
Post by Tim_R »
Haynes says the adjustment should be between 13 and 15mm, I tend to use use an appropriate sized nut as a spacer to set the gear stick up.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Post by mr.brown »
Look down the page here - "77 and later Rabbits" etc
http://arrc.epnet.com/autoapp/8663/8663 ... tments.htm
Risocco
Post by Risocco »
mr.brown wrote:Look down the page here - "77 and later Rabbits" etc
Legend, ta :good:
