Door seals?
Posted: Sun Aug 21, 2011 10:18 pm
by jim91
Are these still available from VW? Scala has a wet rear footwell I just spotted today! I haven't used it much in past year and noticed the passenger side door sticking to rubber a bit and am putting it down to that. My mk2 polo did a similar thing and then the seal started leaking bucket loads!!! Just hoping nothing to do with windscreen!!!!
Re: Door seals?
Posted: Sun Aug 21, 2011 10:46 pm
by MacColl
This is actually more likely the membrane behind the door card and is often not that obvious. Maybe even a slight crack on your scuttle cover (fixed mine with a bit of duck tape) or even a gromet/corrosion in the bulk head allowing water through.
Check your plastic membranes 1st, try tracing it back from where the seal appears to leak. This happened on my old Mk2 Polo and it was the smallest gap in the adhesive/tape that was allowing water through.
Re: Door seals?
Posted: Mon Aug 22, 2011 4:13 pm
by jim91
Cheers dude, hoping for an easy fix and was putting it down to the seal because of sticking. Hate leaks!!!! :crying:
Re: Door seals?
Posted: Tue Aug 23, 2011 12:43 pm
by jim91
Anyone got part number for door seal??
Re: Door seals?
Posted: Tue Aug 23, 2011 5:20 pm
by DT1
867 867 365 G
Re: Door seals?
Posted: Tue Aug 23, 2011 9:36 pm
by Old Mac Rocco
Is this any help ???????
Came up in a search I was doing.
http://www.partspool.com/search/ForSale ... +867+365+G
May be worth following up.
:bye: :bye:
Re: Door seals?
Posted: Wed Aug 24, 2011 9:23 am
by jim91
Brilliant cheers guys! I'm putting it into garage tonight to lift carpet up and get it dried out and try sort exactly where coming from :crying:
Checked the heritage site and they list it for £54. If it cured my issue I wouldn't give a fiddlers at that ££
Re: Door seals?
Posted: Tue Aug 30, 2011 10:07 pm
by jim91
Took seat out and lifted carpet. All dried out, so poured water all around screen and door to see where coming in, but floor has stayed dry. I did put lots rubber care on seals so that maybe make bit difference
I'm gonna put back together and see what happens.
Re: Door seals?
Posted: Wed Aug 31, 2011 11:15 am
by wasted
Sounds odd, but is it possible that the leak's coming from the rear of the car? I'm wondering whether it could be the rear window seal or possibly even something in the boot area...
Re: Door seals?
Posted: Wed Aug 31, 2011 11:25 pm
by jim91
Have it back out garage tonight and back in daily use so I'll see how it gets on.............. it was maybe just angry at me not using it enough :nerner:
Re: Door seals?
Posted: Sun Sep 04, 2011 4:25 pm
by DannyH
commonly the boot lock seal or the badge clips :yup:
Re: Door seals?
Posted: Tue Sep 06, 2011 9:34 pm
by jim91
I replaced the boot loack seal a while ago, but I know 1 badge clip not great. Boot is dry enough though.
We've had mad rain here past few days.............. I'm clinging onto the hope that what I did to the door seals will sort it :crying:
Re: Door seals?
Posted: Sun Sep 18, 2011 12:58 pm
by Turbogirlie
Has yours got a sunroof?
MarkH suspects on my GTX that the channels are blocked, as periodically I get damp in the car. I had a swimming pool in the rear drivers side footwell one time...checking, clearing & replacing channels is not a couple of hours job - I gather you need to remove the headlining inside the car.... :shocking:
Re: Door seals?
Posted: Sun Sep 18, 2011 3:24 pm
by ianaudia4
A quick and easy way to clear the sunroof channels is to buy about 3 metres of tubing that will fit inside the existing channels and feed it through to clear out any debris, this method can also be used to replace but you will need more than 3 metres.
