are bumpers...
Posted: Wed Aug 10, 2011 11:06 pm
by Bonusrocco
...interchangeable?
ie I just removed the tow bar from my 79 gls and then realised the irons are part of the bar which is bolted to the steel insert in the bumpers. I have a spare front bumper - can anyone tell me if the plastics will swap? I'd to avoid trying it as i'm a tad scared of breaking the plastic clips etc...or just call me lazy
any help would be appreciated as i have no rear bumper now.......... :blush:
Re: are bumpers...
Posted: Fri Aug 12, 2011 7:50 am
i've got a mk2 rear bumper sat here that you're more than welcome to rob the metal work from if it's any use to you
Re: are bumpers...
Posted: Fri Aug 12, 2011 12:44 pm
by Bonusrocco
Sounds usefull i'll bear that in mind thanks :good:
So are mk2 irons same as mk1...that is the question!
Re: are bumpers...
Posted: Fri Aug 19, 2011 12:24 pm
by Bonusrocco
bump
Are early mk1 bumper brackets same as late mk1??
Are mk2 brackets same as mk1????
Re: are bumpers...
Posted: Fri Aug 19, 2011 8:56 pm
by vr_powered
Early mk1 and mk2 brackets are both different to late mk1 brackets, could always cut the tow ball off the towbar and use it until you get some proper brackets, not exactly a huge market for mk1 rocco towbars after all....
