Page 36 of 38
Re: 1982 1.5 CL Auto
Posted: Mon Feb 13, 2017 9:46 pm
by The Milkman
steve bain wrote:Thats a very smart headunit and tidy install. Have you stuck your hand through the hole under the stereo when fitting to make sure no wires are trapped? I think I will add a switched live soon, it's annoying not having one!
Yeah, the wires were tucked down the back when I tried it. The ashtray wasn't in so I think once that and the blanking plate next to it are in, you won't notice the gap.
MOT tomorrow
As long as she passes I'll have a go at final fit of the head unit.
Posted: Tue Feb 14, 2017 8:22 am
by Mark H
My headunit stuck out about 3mm when first fitted, was able to bend the plastic tab back enough to fit it flush
Posted: Tue Feb 14, 2017 3:34 pm
by The Milkman
Mark H wrote:My headunit stuck out about 3mm when first fitted, was able to bend the plastic tab back enough to fit it flush
Ah! Cool, I'll give that a try, cheers.
Failed the MOT
Posted: Tue Feb 14, 2017 4:29 pm
by BlackGTX
failed on?
Posted: Tue Feb 14, 2017 7:51 pm
by The Milkman
BlackGTX wrote:failed on?
Rust hole by the nearside front jacking point, brake lights not working and advisory for play in rear wheel bearing.
Luckily the hole wasn't too big, so they welded her up whilst she was in, fitted a new brake light switch and fitted the correct exhaust section for me. All good now.
Posted: Tue Feb 14, 2017 7:52 pm
by The Milkman
Rust repair
Posted: Tue Feb 14, 2017 7:56 pm
by The Milkman
Posted: Tue Feb 21, 2017 6:00 pm
by The Milkman
Got some brass parcel shelf clips from EssexTom....
.....much better
Posted: Tue Feb 21, 2017 6:02 pm
by The Milkman
The headunit I'm using has hands free with a built in mic, but I thought I may as well add an external mic while I'm messing about.
Blaupunkt mic
Posted: Tue Feb 21, 2017 6:03 pm
by The Milkman
Posted: Tue Feb 21, 2017 6:05 pm
by The Milkman
Wiring finally finished. Two ISO blocks, RCA leads for amp (amp power switch lead is in the ISO connector), iPod lead and external mic lead.
Posted: Tue Feb 21, 2017 6:08 pm
by The Milkman
Posted: Tue Feb 21, 2017 6:10 pm
by The Milkman
Posted: Tue Feb 21, 2017 9:10 pm
That does look nice a tidy, what model headunit is that?
To save your car battery its better to remove the main earth cable from the battery, you will need to keep setting the clock in the car.
Posted: Tue Feb 21, 2017 10:13 pm
by The Milkman
mark1gls wrote:That does look nice a tidy, what model headunit is that?
Cheers, it's a Blaupunkt Toronto 420BT.
I don't think the head unit will be that much of a drain, but as she only gets used about once a month at the minute I don't want to take the risk. The new fuse I've wired in is nice and easy to get to and then no live to drain the battery.
