Page 35 of 38
Re: 1982 1.5 CL Auto
Posted: Mon Feb 06, 2017 1:07 pm
by The Milkman
Posted: Mon Feb 06, 2017 1:10 pm
by The Milkman
Joints all soldered, haven't bothered with the illumination dimmer wire (may do, but not sure what to wire it to). Only heat shrank a couple of the joints until I can get some fuses and make sure it all works ok. Once the head unit is working I can work out the speaker wires and fit another ISO plug on them. Hopefully when it's all done it should have two, properly wired ISO plugs.
Posted: Mon Feb 06, 2017 1:26 pm
May be a bit late but is one of the spade connectors in G a switch live?
https://vwgolfmk1.org.uk/forum/index.ph ... ost_788114
Posted: Mon Feb 06, 2017 2:14 pm
by steve bain
fair enough. my amp cable is the same size as my finger! i think i went a bit ott though!
Posted: Tue Feb 07, 2017 8:21 am
by The Milkman
Never too late, always handy to know this stuff
Posted: Tue Feb 07, 2017 8:24 am
by The Milkman
steve bain wrote:fair enough. my amp cable is the same size as my finger! i think i went a bit ott though!
It does seem that over the years amp cables have got thicker and thicker but I don't think the little ones draw a lot of ampeage, I normally have them running a 10a fuse.
The cable on this is probably one of the thickest I've used. I had a New Beetle a few years ago and it was a pain in the arse trying to get a live feed through the firewall. In the end I cut the plug off of a car hoover, wired that to the amp and plugged it into the 12v socket in the rear
Posted: Mon Feb 13, 2017 5:53 pm
by The Milkman
Before I finished the power ISO plug I needed to check that it all worked
Woo Hoo!!
And when you switch the ignition off
Posted: Mon Feb 13, 2017 5:57 pm
by The Milkman
Finished soldering and heat shrinking the joins
Two thicknesses of heat shrink for a snug fit on both wires, you can see the thinner one covering the joint on the yellow wire with the thicker one further up the wire.
Posted: Mon Feb 13, 2017 6:01 pm
by The Milkman
Very happy with the end result, nice and tidy
Posted: Mon Feb 13, 2017 6:03 pm
by The Milkman
Posted: Mon Feb 13, 2017 6:05 pm
by The Milkman
Tried the head unit in place
It doesn't quite fit all the way home as there is a plastic mount behind it. I don't really want to chop that out (never know if you'll decide to go back to stock one day) it's only a couple of mm so I don't think it will really notice.
Posted: Mon Feb 13, 2017 6:07 pm
by The Milkman
Finished stereo wiring, two new ISO connectors, amp leads and ipod connection.
I still have one rear speaker to connect up, fit amp and sub, tidy the wiring in the boot....
Posted: Mon Feb 13, 2017 8:11 pm
by Mark H
Fitted a Blaupunkt London in my Rocco, replaced speakers with Alpine 6x4. Good sound and function for the money
Posted: Mon Feb 13, 2017 8:28 pm
by The Milkman
Mark H wrote:Fitted a Blaupunkt London in my Rocco, replaced speakers with Alpine 6x4. Good sound and function for the money
Good to know. Hopefully with that lot plus the sub to add some extra depth it should sound pretty good. Fingers crossed.
Posted: Mon Feb 13, 2017 9:36 pm
by steve bain
Thats a very smart headunit and tidy install. Have you stuck your hand through the hole under the stereo when fitting to make sure no wires are trapped? I think I will add a switched live soon, it's annoying not having one!
