That's as far as I got, decided that I'm going to go the whole hog and fit new ISO connectors so they have been ordered (along with heat shrink tubing) just waiting for them to arrive.
Ipod lead needs to be run, not sure where to yet
Also still need to wire the rear speakers and fit the amp/sub
someones a bit spendy before xmas! is the exhaust unique to the 1.5? or does it fit 1.8 etc? makes a surprising difference having a new exhaust and new filter. more revy.
steve bain wrote:someones a bit spendy before xmas! is the exhaust unique to the 1.5? or does it fit 1.8 etc? makes a surprising difference having a new exhaust and new filter. more revy.
Yeah, the Mrs won't see the credit card bill for a few weeks yet
I believe it's for all the big block engines. I'm hoping it does make a difference, I haven't had a full exhuast and manifold fitted on anything other than an aircooled. Apparently the 1.5 JB engine is strangled by the exhaust manifold.
Clerance is an issue...James removed the centre and had a straight through, mine broke after 18 months (I went back to stock) although it must have scraped every speed bump it went over whilst I had it.
There should be a clamp for the rear box that you can use instead of the hanger that's welded onto the rear pipe behind the muffler, you can then rotate the back box a bit and should help with routing the pipe over the beam. I ended up cutting that hanger off to get a better fitting as it just got in the way.
Probably not the sort of things you want to hear...sorry.
