A spare couple of hours this morning sees the new cam seal and cam belt fitted. The belt didnt look that old, but it was contaminated with oil from the cam seal leak, so i changed it anyway. Stripped down ready for the new parts....
Then built it back up, painted the rocker cover and upper belt cover and ditched the bolt on K&N air filter and fitted a standard airbox (cheers Kieran) with a new filter...
Just need to recheck the ignition timing with a strobe light now. Also want to finish cleaning up the engine bay and paint the rad fan cowling.
Another big step forward was to fit a decent set of seats, these are early mk2 seats and the rear seats have the split upper back bench, so i need to tack weld a plate with some studs fitted to secure it, and the lower bench doesnt have the two metal tabs that are screwed to the car, so il have to make a pair of these too, easy enough to do. It looks a million times better inside now.
I think this is almost finished now...
