Well, MOT today! - I had a quick look a the previous advisory sheets and thought i'd put it in and see what they said.. (Draycott Engineering in Didcot).
Needless to say it failed on a few little bits: Front springs (both broken) - which I knew about, rear wheel bearing play, front brake in-balance, badly fitted rear brake hose and a split steering rack gaiter.
I never drive the car on the limit or anywhere near it so hadnt noticed the front brake in-balance.. The rear wheel bearings were an advisory on the last, so that wasn't much of a suprise..
Much against my normal approach of doing it myself (I just cant be assed with the weather as it is at the moment) I dropped my new front dampers and stut cases and top mounts down along with some new VAG springs, along with a new gaiter. They fitted all that along with a new rear brake hose for me. the rear wheels bearings nipped up fine, and the slider pins on the front brakes were all cleaned and re-lubricated. Had the tracking downe for good measure - So now we have the all important PASS!
The bloke said what a nice example it was, and completely rot free for a change!
Hopefully going to get all 4 wheels off and on stands this weekend for a spot of steam cleaning and waxoiling and general winter weather preperation. So i'll put some long overdue pic up then!
Henry
Motorsport is my passion.
