Page 4 of 7
Re: 87 Black GTX
Posted: Sat Mar 04, 2017 11:34 pm
Tidy bit of wrapping there.
Re: 87 Black GTX
Posted: Sun Mar 05, 2017 8:24 am
by BlackGTX
mark1gls wrote:Tidy bit of wrapping there.
thanks, scrappy gave me a hand with the rear pipe and can confirm that this stuff itches
happy with the down pipe but it may be in vain, my abf is kjet but has an ecu so may need a lambda i can use a rocco 16v ecu too but need to look into if they use one. hopefully its only needed as part of the digi setup
still to do the top of the manofold and see how it sits on the uj
Re: 87 Black GTX
Posted: Sun Mar 05, 2017 9:55 am
by steve bain
Black wrap. Very nice. I did mine in white and I am now wondering why!
Re: 87 Black GTX
Posted: Sun Mar 05, 2017 10:36 am
by BlackGTX
i did look at gold and red wrap but i know for a fact my greasy hands will be all over it and ruin the look so black it is
Re: 87 Black GTX
Posted: Mon Mar 06, 2017 3:49 pm
by scrappy1382
yes inddedy, very very itchy... so much so, i binned the jumper i was wearing. thanks kieran ;-)
Re: 87 Black GTX
Posted: Sat Mar 11, 2017 5:55 pm
by BlackGTX
some more wrapping,
made space for the lambda sensor, working round it was quite complicated
wrapped the upper part to but photobucket is in no hurry for it to show in my gallery
Re: 87 Black GTX
Posted: Fri Mar 17, 2017 4:52 pm
by BlackGTX
cleaned the brake rez using gunk engine degreaser
Re: 87 Black GTX
Posted: Sat Mar 18, 2017 6:48 pm
by BlackGTX
swapped the braken res over and fitted the wrapped 421,
as expected it touches the wrapped uj but 2 layers of wrap should do it
also got some scirocco 16v injector lines, look brand new although they dont fit the dx injectors. they slide right over the top of the dx injector without having to thread and the internal thread is fewer and wider spaced, 5 rather than 8
Re: 87 Black GTX
Posted: Sat Mar 18, 2017 9:32 pm
by scrappy1382
kieran, im sure i have a set of injector lines . both styles in the garage. want me to bring them over monday ? message me pal. heat wrap round the uj boot and exhaust should be good enough. i dont have any issues
Re: 87 Black GTX
Posted: Sun Mar 19, 2017 8:31 am
by BlackGTX
scrappy1382 wrote:kieran, im sure i have a set of injector lines . both styles in the garage. want me to bring them over monday ? message me pal. heat wrap round the uj boot and exhaust should be good enough. i dont have any issues
im gonna get some new injectors, found a seller doing them for around 35 a go
ive got dx and abf lines but neither is long enough for all 4 lines as 2 have to bend round the back of the metering head. ill post a pic soon and itll make more sense
Re: 87 Black GTX
Posted: Sun Mar 19, 2017 8:32 am
by scrappy1382
Ok
Sent from my Moto G Play using Tapatalk
Re: 87 Black GTX
Posted: Wed Mar 22, 2017 10:56 am
by BlackGTX
small progress
bought some 16v injectors
finished the water pipes and fuel lines so just vaccume pipework to complete the induction
Re: 87 Black GTX
Posted: Mon Mar 27, 2017 11:58 pm
by scrappy1382
Keep it up bud.
Re: 87 Black GTX
Posted: Wed Mar 29, 2017 8:16 pm
by BlackGTX
it all fits together
Re: 87 Black GTX
Posted: Sun Apr 30, 2017 10:45 am
by BlackGTX
more progress,
tapped the abf throttle body to take the 16v cable holder, never tapped a hole before so took it slow and steady and worked opposite corners
gave me an interesting problem as all 16v roccos are lhd so the cable doesnt fit neither does uk 16v cables so took advice on a mk2 golf 1.3 cable
