87 Black GTX
Re: 87 Black GTX
Tidy bit of wrapping there.
Re: 87 Black GTX
thanks, scrappy gave me a hand with the rear pipe and can confirm that this stuff itchesmark1gls wrote:Tidy bit of wrapping there.
happy with the down pipe but it may be in vain, my abf is kjet but has an ecu so may need a lambda i can use a rocco 16v ecu too but need to look into if they use one. hopefully its only needed as part of the digi setup
still to do the top of the manofold and see how it sits on the uj
steve bain
Re: 87 Black GTX
i did look at gold and red wrap but i know for a fact my greasy hands will be all over it and ruin the look so black it is
- scrappy1382
Re: 87 Black GTX
BlackGTX wrote:thanks, scrappy gave me a hand with the rear pipe and can confirm that this stuff itchesmark1gls wrote:Tidy bit of wrapping there.
yes inddedy, very very itchy... so much so, i binned the jumper i was wearing. thanks kieran
Scirocco Shane
84 Havanna Brown Storm -
Re: 87 Black GTX
some more wrapping,
made space for the lambda sensor, working round it was quite complicated
wrapped the upper part to but photobucket is in no hurry for it to show in my gallery
Re: 87 Black GTX
swapped the braken res over and fitted the wrapped 421,
as expected it touches the wrapped uj but 2 layers of wrap should do it
also got some scirocco 16v injector lines, look brand new although they dont fit the dx injectors. they slide right over the top of the dx injector without having to thread and the internal thread is fewer and wider spaced, 5 rather than 8
- scrappy1382
Re: 87 Black GTX
kieran, im sure i have a set of injector lines . both styles in the garage. want me to bring them over monday ? message me pal. heat wrap round the uj boot and exhaust should be good enough. i dont have any issues
Scirocco Shane
Re: 87 Black GTX
im gonna get some new injectors, found a seller doing them for around 35 a goscrappy1382 wrote:kieran, im sure i have a set of injector lines . both styles in the garage. want me to bring them over monday ? message me pal. heat wrap round the uj boot and exhaust should be good enough. i dont have any issues
ive got dx and abf lines but neither is long enough for all 4 lines as 2 have to bend round the back of the metering head. ill post a pic soon and itll make more sense
- scrappy1382
Re: 87 Black GTX
Ok
Sent from my Moto G Play using Tapatalk
Scirocco Shane
Re: 87 Black GTX
small progress
bought some 16v injectors
finished the water pipes and fuel lines so just vaccume pipework to complete the induction
- scrappy1382
Re: 87 Black GTX
Keep it up bud.
Scirocco Shane
Re: 87 Black GTX
more progress,
tapped the abf throttle body to take the 16v cable holder, never tapped a hole before so took it slow and steady and worked opposite corners
gave me an interesting problem as all 16v roccos are lhd so the cable doesnt fit neither does uk 16v cables so took advice on a mk2 golf 1.3 cable
