Page 3 of 14
Re: 1980 GLS
Posted: Tue Jan 04, 2011 5:07 pm
by Bill
What can i say fella, working your Rocco magic again, some lovely cars starting to appear on this page
, boy i need more space.
Re: 1980 GLS
Posted: Sun May 15, 2011 8:52 pm
by The Autoad
Re: 1980 GLS
Posted: Sun May 15, 2011 10:15 pm
by Cpt Custom
The Autoad wrote:Lots going on, moved into a new manspace with a couple of pals ...
The Rocco Grotto has moved?
Re: 1980 GLS
Posted: Mon May 16, 2011 6:05 pm
by The Autoad
On the same site Paul, but moved the grotto a few metres to the left, to the back of the massive unit that we were in working on Sean's car when you came for your visit. Works out great for us all.
Re: 1980 GLS
Posted: Thu Jun 09, 2011 11:25 pm
by The Autoad
The inner wings on both sides of the car needed work.
So I had a go at using the inner wing repair panels supplied for a MK1 Golf. I knew that they were not exactly the correct shape required and that they would require sectioning, but to be honest I only used a small amount of them. For the amount of bashing required to get the repair panel to sit neat against the suspension turret you may as well measure up and make your own. Which is what I ended up doing here:
Mk1 Golf inner wing section used here (it needed a bit of farting about, i prefer the homemade repair above):
Seam sealer after primer, shutz to follow. Indy cowls were repaired too.
Back to other side, from engine bay (with Golf 1 bit at front)
Bit of the crusty stuff on the front panel
Re: 1980 GLS
Posted: Fri Jun 10, 2011 11:42 am
by mr.brown
Was gold the only available colour for a 1980 GLS?
Good work btw ;)
Re: 1980 GLS
Posted: Fri Jun 10, 2011 12:38 pm
by filmidget
At least the wheels appeared to have stayed on this one...
Re: 1980 GLS
Posted: Tue Jun 14, 2011 12:52 pm
by The Autoad
mr.brown wrote:Was gold the only available colour for a 1980 GLS?
You'd think it wouldn't you, as they all seem to be bloody gold. But i think there were other colours, Indiana Red, River Blue and Platinum spring to mind.
Spotted this.
quick blast of the needle scalers revealed more rot at the bottom of the sill and at the rail, plus lots of filler hiding a big ole dent in the sill. It wasnt a bad repair of the dent, but i wanted to weld new metal in for the bottom of the sill and couldn't find good metal without removing a ton of filler.
so only one thing for it.
started to rebuild inner sill and rail.
and new outer on.
Re: 1980 GLS
Posted: Tue Jun 14, 2011 2:53 pm
by Cpt Custom
Awesome work!
Re: 1980 GLS
Posted: Tue Jun 14, 2011 5:13 pm
by Winston
Skills!!!!
You make it look so easy.
Re: 1980 GLS
Posted: Tue Jun 14, 2011 6:04 pm
by Bill
my flabber has never been so gasted, you see it you do it, my hats off to you cheif
Re: 1980 GLS
Posted: Tue Jun 14, 2011 8:59 pm
by shavhead
there is some excellent work going on in the new grotto lately well done my man
Re: 1980 GLS
Posted: Wed Jun 15, 2011 5:11 am
by markh
Brilliant !
Re: 1980 GLS
Posted: Tue Jul 12, 2011 9:28 pm
by The Autoad
Had a go at repairing the original drivers door.
Rusty bottom and lifting filler.
Got rid of the bottom of the skin to reveal the mess, the frame itself wasn't too bad beneath the surface rust, just needed a scrub with a wire brush, a few new sections letting in and rust killer.
Cut away a bit more of the skin and used a repair panel to renew.
Acid test. With a wee bit of fettling to the rear corner of the pattern sill the door fits -phew!
Re: 1980 GLS
Posted: Tue Jul 12, 2011 10:10 pm
by DT1
Looks like a great job.
