Page 3 of 38
Re: 1982 1.5 CL Auto
Posted: Sun Mar 23, 2014 9:45 am
by the edmundator
Yes, the econometer should nag you to change gear with a yellow light pretty much all the time until you're in top. I'm not sure whether the light would work in an auto, though. The swingometer should still pretend to give you an idea of fuel economy though.
Posted: Sun Mar 23, 2014 10:21 am
by Radorocco
the edmundator wrote:Yes, the econometer should nag you to change gear with a yellow light pretty much all the time until you're in top.
Indeed. Used to really get in my t*ts after a while :-D
Jeff
Posted: Sun Mar 23, 2014 10:40 am
by ianaudia4
The gear shift indicator works by a series of vacuum hoses, first things to check as very often overlooked!
I think VW were very forward thinking when they launched the concept back in the early '80's, some of our company cars (which are all less than a year old!) have then fitted!
Posted: Sun Mar 23, 2014 11:14 am
by Reverend Frog
ianaudia4 wrote:The gear shift indicator works by a series of vacuum hoses, first things to check as very often overlooked!
My econometer works OK, but i doubt it is really of much value beyond being quite a cool thing to have.
It tells me that i can go from 50 to 25 mpg just by pressing the throttle slightly
Plus my car has never in its life done 50 mpg. on my way home from London it probably managed 40-ish tops.
Posted: Sun Mar 23, 2014 11:35 am
by ianaudia4
40 ish is a good MPG, there are plenty of modern cars that would struggle to achieve that!
Posted: Sun Apr 27, 2014 6:20 pm
by The Milkman
Had a little play today
Front mudflaps off to start
Only bit of rust on the drivers front wing
Posted: Sun Apr 27, 2014 6:23 pm
by The Milkman
Looks pretty clean on the inner wing
Posted: Sun Apr 27, 2014 6:25 pm
by The Milkman
Posted: Sun Apr 27, 2014 6:28 pm
by The Milkman
Passenger side not quite as clean, looks like crap has sat behind the mudflap and rotted through fro the inside out
Posted: Sun Apr 27, 2014 6:31 pm
by The Milkman
Took the inner liner out, load of wet mud and crap behind where the mudflap sat
Posted: Sun Apr 27, 2014 6:33 pm
by The Milkman
Apart from that it looks pretty clean this side as well. Although for some reason it all looks to be body colour this side, where as there looked to be some sort of rust proofing the other side.
Posted: Sun Apr 27, 2014 6:35 pm
by The Milkman
All the screws for the mudflaps and inner liners came out fine apart from this bugger, bit of violence soon got the liner out.
Posted: Sun Apr 27, 2014 6:38 pm
by The Milkman
Had a look at the fuel filler neck, doesn't look too bad to me, one small section that I might replace with a bit of flexi. Inner arch looks pretty clean.
Posted: Sun Apr 27, 2014 6:40 pm
by The Milkman
The white bit is a previous repair that someone has done, looked like it had rusted right through. I'll get a proper repair done at some point.
Posted: Sun Apr 27, 2014 6:41 pm
by The Milkman
Rest of the arch looks clean
